4000 ford pto sfaft problem
   / 4000 ford pto sfaft problem #1
pawpawtom
Ciyronelle Al.
Ford 4000
The pto sfaft on my 4000 ford came out while I was bushhogging. I need to know is there a retainer or anything that holds the shaft in that might have broken or come loose. Thanks for any help. PPT
   / 4000 ford pto sfaft problem #2
Which 4000? Pre 1965 4 cylinder model or post 1965 3 cylinder?
Always mention which.
If pre 65 it is a simple task to remove the 4 bolts in the flange and pull the flange, bearing and PTO shaft out.
There is a circlip that holds the bearing and oil seal into the flange that likely came out.
It is a post 1965 3 cylinder. Is the fix different?
Makinex Power Lifter (A52377)
Makinex Power...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A51248)
UNUSED WOLVERINE...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A52577)
2019 INTERNATIONAL...
Pallet Fees (A50775)
(INOP) 2016 GENIE TZ-34/20 TOWABLE BOOM MANLIFT (A51247)
(INOP) 2016 GENIE...
UNUSED WOLVERINE...
