4035- anti freeze fluid drain
   / 4035- anti freeze fluid drain #1
RedFirstGen
Finger Lakes NY
Mahindra 4035
I want to change the anti freeze fluid in my 4035. I located the drain on the bottom of the radiator. Is that the only drain? Also, just drain it all and add the new?...or should I do something to flush out any "crap". Thanks In advance.
   / 4035- anti freeze fluid drain #2
On my tractor (not a 4035) I also had a drain on a lower hose that also flushed the block.
For sure flushing with fresh water should greatly help to rid of any crud.
There are flushing or cleaning products at auto supplies to help clear out a rad and block and I believe that generally they consist of a caustic solution.
Cleaning/flushing certainly won't hurt and your tractor will thank you.
   / 4035- anti freeze fluid drain #3
Thank you both. The manual is most def helpful. I guess I just need to find the other drain on the crankcase.
   / 4035- anti freeze fluid drain #5
That is just the operator's manual. It has all the general service information and intervals detailed in it. Once Mahindra is done updating the 24x7 Owner's site, you'll be able to log in with the serial number of your tractor and download a copy of it for free.
Nice! Thanks
2009 MACK GRANITE (A52472)
2009 MACK GRANITE...
2017 CHALLENGER MT465E TRACTOR (A51406)
2017 CHALLENGER...
2011 ORTEQ ENERGY SERVICES 40 MANIFOLD TRAILER (A52472)
2011 ORTEQ ENERGY...
EVERYTHING SOLD AS-IS WHERE IS!! (A50775)
EVERYTHING SOLD...
2014 BMW 320i Sedan (A50324)
2014 BMW 320i...
