4035 FEL control is sticking
   / 4035 FEL control is sticking #1
Sysop
Elite Member
Fairmont, WV
Mahindra 4035HST purchased 2013 - Husqvarna TS348-D purchased 2019 - Craftsman 42" HST purchased 2003
Anyone got any advice for the best method of handling it? Up and down are fine, curl is what sticks.
Thanks for any input!
   / 4035 FEL control is sticking #2
Mine started doing same thing and adjusting it did not help. I took the cable off and it was hard to pull it through because of a burr in it. I replaced cable and problem solved. Hope this helps.
   / 4035 FEL control is sticking #3
I had some corrosion under the caps of the loader control valve. pull the caps off the valve by removing the 2 allen cap screws. hose out with wd 40 and reassemble.
   / 4035 FEL control is sticking #4
Thats usually where I start.Once its cleaned I like to lube it up with grease. Careful on the lift spool if you check that one. Don't loose your detent spring and balls. :thumbsup:
   / 4035 FEL control is sticking #5
" I lost my balls, in Fairmont West Virginny.... High on a hill, they call to me.... " [ Tony Bennett singing in the background... ]
2004 JOHNSTON STREET SWEEPER (A52577)
2004 JOHNSTON...
2017 Taylor-Dunn B0-248-36 Electric Utility Cart (A50322)
2017 Taylor-Dunn...
Unused 2025 CFG MH12RX Mini Excavator (A50322)
Unused 2025 CFG...
2018 FORD F-150 XL CREW CAB TRUCK (A51406)
2018 FORD F-150 XL...
2016 BMW X5 sDrive35i SUV (A50324)
2016 BMW X5...
2009 Ford F-250 Ext. Cab Knapheide Service Truck (A50323)
2009 Ford F-250...
