4035, Steering Wheel Pedal Spring or Differential Pedal Spring Replacement
   / 4035, Steering Wheel Pedal Spring or Differential Pedal Spring Replacement #1
tjus77
Bronze Member
Montgomery, TX
Mahindra 4035
Both my steering wheel adjustment pedal and my differential lock pedal springs have quit working. They look like some sort of cam. Has anyone tried to replace theirs, or is this better left up to the dealer??
   / 4035, Steering Wheel Pedal Spring or Differential Pedal Spring Replacement #2
The steering wheel has a gas strut that moves the colum up and down the diff lock can be cleaned and adjusted
the gas strut is not the problem, it is locking it into place that is the problem, the tension on the lock no longer works and the steering wheel just eases back into the up position. Same with the lock, it will work, but I have to manually lift the pedal back up to disengage
2006 FORD F-250 (A52472)
2006 FORD F-250...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A52748)
2016 KBH...
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
LEONARD 16 ENCLOSED TRAILER (A52472)
LEONARD 16...
2024 BRAZOS  53FT ALUMINUM STEP DECK (A52472)
2024 BRAZOS 53FT...
Cruise Car Electric Utility Cart (A51691)
Cruise Car...
