3-Point Hitch 4052R pto issue
   / 4052R pto issue #1
Ljh815
Carbondale il
JD 4500
Hey guys... I have a 4052R with 78 hrs. Didn稚 get much snow this year so it sat a few months unused. Hooked up the tiller today preparing for spring garden, and the pto shaft is not spinning. Pto light on dash comes on, so I assume that eliminates the switch.
Anyone else had this problem?
Any ideas?
   / 4052R pto issue #2
Did you check to see that the PTO/E-PTO lever is in gear?
   / 4052R pto issue
Sorry, not sure what you mean.
   / 4052R pto issue #4
If your tractor has the E-PTO option, you will have a shift lever on the right side of the operator station near the 3 point raise/lower lever. The PTO shifter has a big yellow knob on it. Make sure that it’s in position for either standard or E-PTO, and not in between gears.
Genie GTH-644 (A50490)
2012 Ford F-150 Crew Cab Pickup Truck (A49461)
2012 Ford F-150...
2023 PJ 49FT Gooseneck Trailer - 35+5, Mega Ramps, 30,000 GVW, Electric Brakes (A51039)
2023 PJ 49FT...
2001 GMC W4 CRANE TRUCK (A51222)
2001 GMC W4 CRANE...
F-500 POWER PUMP 500HP TRIPLEX POWERED BY 3412 CATERPILLAR ENGINE (A50854)
F-500 POWER PUMP...
BUSH WACKER ST-180 ELITE BATWING ROTARY MOWER (A51406)
BUSH WACKER ST-180...
