Loader 4100JD / 410 front end loader raising issue
   / 4100JD / 410 front end loader raising issue #1
deeganjd
Red Banks, Ms.
John Deere 4100
The loader was working fine. A few days later I went to use the tractor and the loader would only raise up about 1 foot from the ground and stop. It would go back down fine. The bucket operates fine and tilts forward and back as it should. Just can not seem to figure the problem out any help? Thanks Jim
   / 4100JD / 410 front end loader raising issue #2
Unplug ALL four of the QD's (quick disconnects) for the loader, wipe them clean (inside the female, outside the male) and reconnect everything. I'll bet you a sweet tea everything will work after that.
It is not uncommon for the QD's to "look" connected, but not be.
Thanks a bunch for the info. I took them apart, cleaned and put back on, all works great. One did look like it was not connected good when I took it apart but I took all off and cleaned to be on the safe side. Thanks again, Jim
2007 Case IH 2588 4WD Combine (A50657)
2007 Case IH 2588...
Bad Boy Maverick 5200 Zero Turn Mower (A50514)
Bad Boy Maverick...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
2008 INTERNATIONAL DURASTAR 4300M7 SBA 4X2 DUMP TR (A51243)
2008 INTERNATIONAL...
Heavy Duty Skid Steer Auger ECAG W/ 6", 12", and 14" Bits (A47384)
Heavy Duty Skid...
Kubota SVL95-2 High Flow Cab Skid Steer (A52128)
Kubota SVL95-2...
