4110 JD and wagon to haul fire wood
   / 4110 JD and wagon to haul fire wood #1
roermo
Hannibal MO.
4110 JD
I have a 4110 for now, I might go up to a 3520, but if I stick with the 4110, I can buy more stuff with it. Here is my quesiton how large of a wagon can I pull off the draw bar, I think I know a 5x10 would be to large. I found one that can hold 7,000 pounds double axle. Simple math says that more than three time the tractor weight of 1900 pounds. So going to the 3520 would help but still too much weight. So what will the two tactors pull if my fel is loaded with dirt or rock. any help out there.
I have rake rear blade and bucket.
thanks
roger.
   / 4110 JD and wagon to haul fire wood #2
If the trailer has brakes, it sounds like John Deere is saying you can go up to 7000 lbs towing (see below). They would have to be hydraulic surge brakes or you would have to add an electric brake controller.
Even still, I wouldn't plan on going that high with this small tractor on a regular basis. It likely won't be able to pull that much weight up an incline. Adding ballast will give the tractor more traction, but will not increase its tractive force, so it will be even less capable of pulling the gross combined weight up an incline.
Occasional pulling of something that heavy on level pavement - probably OK. For example, I use my 4100 to move a 5000 lbs boat around the driveway, but I wouldn't expect it to pull it up a launch ramp (or even feel safe backing it down the ramp)!
From the 4110 owners manual:
Towing Loads
CAUTION: Avoid injury! Stopping distance increases with speed and weight of towed load, and on slopes. Towed loads with or without brakes that are too heavy for the machine or are towed too fast can cause loss of control. Consider the weight of the equipment and its load.
Observe these recommended maximum road speeds, or local speed limits which may be lower:
If towed equipment does not have brakes, do not travel more that 32 km/h (20 mph) and do not tow loads more than 1.5 times the tractor weight.
If towed equipment has brakes, do not travel more than 40 km/h (25 mph) and do not tow loads more that 4.5 times the machine weight.
Ensure the load does not exceed the recommended weight ratio. Add ballast to recommended maximum for machine, lighten the load, or get a heavier towing unit. The machine must be heavy and powerful enough with adequate braking power for the towed load. Use additional caution when towing loads under adverse surface conditions, when turning, and on inclines.
   / 4110 JD and wagon to haul fire wood #3
Realistically what are the odds of you loading a 5 x 10 to 7,000 pounds? More than likely your going to need the space for lighter stuff like brush, grass clippings or whatever.
It's better to have a bigger trailer (wagon whatever) and not load it to capacity on heavy stuff than it is to have a smaller trailer that you have to make a thousand trips with on stuff that won't pack.
2023 Kubota LX2610SUHSD MFWD Compact Tractor with LA535 Front Loader (A56435)
2023 Kubota...
2020 CAT 308 (A53317)
2019 CATERPILLAR 326FL EXCAVATOR (A52709)
2019 CATERPILLAR...
2013 BMW X5 xDrive50i AWD SUV (A56859)
2013 BMW X5...
204158 (A57193)
204158 (A57193)
2011 DOOSAN G40 GENERATOR (A55745)
2011 DOOSAN G40...
