4110 rear/aux hydraulics
   / 4110 rear/aux hydraulics #1
MGnnr24
MO
4110 Mahindra
I've had my tractor for awhile now but never used the auxillary hydraulics, I remember when I bought the tractor the dealer showed me the lever next to the 3-point controls and said this runs the rear hydraulics. Well Dad has his brush hog all hooked up and ready to go, and this lever isn't working, I've looked in the owners manual and can't find anything that says anything about the operation of these.
Can any of you guys help me out?
Matt
   / 4110 rear/aux hydraulics #2
Matt,
The lever next to the 3ph controls is the draft control. The control for the rear hydraulics are behind the seat, left to right I believe...
It's the same on my 3510.
Yeah, the manual is pretty lame...
-JC
   / 4110 rear/aux hydraulics #3
Must be a pretty good size bush hog if you need to use the hydraulics. A small lever next to the seat controls the rear remote hydraulics. It will go back and forth but is spring loaded to stay in the middle (neutral) position. If your FEL works, the rear remote should work. Good luck.
48" WIDE WOODEN STAIRCASE W/ METAL RAILING (A54757)
48" WIDE WOODEN...
GooseNeck Trailer (A52377)
GooseNeck Trailer...
2025 12V Diesel Pump and Hose (A50324)
2025 12V Diesel...
23018 (A53424)
23018 (A53424)
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2020 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A54607)
2020 INTERNATIONAL...
