4110 water pump rebuild--possible?
   / 4110 water pump rebuild--possible? #1
al3
Central Wi
JD 4110, X500
Well, my water pump has started to seep fluid from the weep holes; bad seal. Can see the pump is designed with what appears to be a removable backing plate. Has anyone every rebuilt one of these? If so, where did you find the replacement seal?
Also, maintence manual shows an O-ring in addition to a backing plate gasket. Anyone that had their's apart know if there is still one in there? Dealer thought not. Thks
   / 4110 water pump rebuild--possible? #2
I'm not familiar with your pump but there may be more than the seal needs replacing?
Bearings?? Shaft??:confused:
   / 4110 water pump rebuild--possible? #3
IMO, if you can not replace the impeller as well then is probably not worth rebuilding. You can try to match up parts with a Yanmar dealer but they will probably not be able to look up parts based on s/n as it will not show any info in their system due to an mfg agreement with Deere (typically). $250 for a pump IS steep I think but not too bad. Good Luck
UNUSED WOLVERINE RPR-12-72W 72" RIPPER (A54757)
UNUSED WOLVERINE...
UNUSED FUTURE FT15J EXCAVATOR (A54756)
UNUSED FUTURE...
JOHN DEERE 5125R (A53084)
JOHN DEERE 5125R...
Target Ecoline Walk-Behind Concrete Saw (A49461)
Target Ecoline...
2017 Ford F-550 Enclosed Service Truck (A55788)
2017 Ford F-550...
2023 KAUFMAN MINI V CAR HAULER TRAILER (A54607)
2023 KAUFMAN MINI...
