The rockershaft lift will not come up unless I move the lever all the way into the up position. and if I leave the lever in the full up position you can hear it laboring and I cannot adjust the height.
The John Deeere dealer says the Rockershaft valve is bad. He suggested I check the screen in the hydraulic system and see if it is dirty, I changed the filters. Did not help. The new valve is $500.00, however, I found one on the web for 250,
Does anyone have any suggestions as to whether something besides the valve could be causing this. Is it safe to buy cheap parts.
Thank You:
Thank You:
