4310 E-Hydro Stops after 30 minutes
   / 4310 E-Hydro Stops after 30 minutes #1
lakecityneil
My Dad's 4310 will just stop like you pulled your foot off the pedal after about 30 minutes of run time. The engine and transmission seem to be in perfect mechanical condition. After the tractor sits (turned off) for about 30 minutes it will run fine again for about 30 minutes.
I bypassed the seat switch and still have the problem....
I'm trying to decipher the flashing code.....
Any advice or information would be greatly appreciated!
   / 4310 E-Hydro Stops after 30 minutes #2
What is the flashing code.. post the picture you see. Probably some kind of warning indicator that is cutting the trans out.
Good thing that you weren't in the middle of an intersection or a railroad track when all that modern technology decides to flash a lamp and cut out that 'perfectly good working order' transmission.
I'm glad none of my gear tractors flash a lamp then disengage the tranny.... one reason why I'm staying gear till I have a good reason to do otherwise... There is something to be said about a solid mechanical connection between the rear wheels and the crank shaft / starter.. etc..
Post back.. and good luck.. hopefully it is a easy/cheap fix.. and not one of those 'holes' that you have to wad up money and stuff in till the hole is filled.
Soundguy
   / 4310 E-Hydro Stops after 30 minutes #3
If you'll post the flash sequence maybe someone can help?
   / 4310 E-Hydro Stops after 30 minutes #4
"i saw the check engine light.... so i stopped... opened the hoood and looked...
yep still there"
   / 4310 E-Hydro Stops after 30 minutes #5
yep still there"
Sounds like you had a malfuction :D
   / 4310 E-Hydro Stops after 30 minutes #6
Hey.. you been talkin' to my wife?
That's her engine diagnosin' type of skill level.. (grin)
Soundguy
yep still there"
What is the 7I0?
MURRAY PUSH MOWER (A53843)
MURRAY PUSH MOWER...
2016 Chrysler 200 Limited Sedan (A50324)
2016 Chrysler 200...
2015 MACK CXU613 MID-ROOF SLEEPER (A53843)
2015 MACK CXU613...
2012 INTERNATIONAL DURASTAR 4300 BUCKET TRUCK (A51406)
2012 INTERNATIONAL...
2018 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2018 DRAGON 150...
2019 CATERPILLAR 926M WHEEL LOADER (A52705)
2019 CATERPILLAR...
