4400 engine overhaul
   / 4400 engine overhaul #1
City Farmer
Platinum Member
Chesterfield, Mi
Ford 3000, 4400 & 4500TLB Case 830 Case 350 dozer
Hi all, I've had this 4400 (gas) for a while a now and I refuse to let it become scrap. Last fall I had the (13')BH hooked up to it and it instantly sucked the life outta this o'l girl. She was tired and I knew I was pushing it. As soon as I started moving the dipper around it was over. To give you an idea of how bad it is, I park it in an out building that has a sand floor. When I was pulling out for the first time last week, I had to engage the diff. lock. It went from 1800rpm to a stall almost instantly.
Now, it's time for an overhaul. I've never rebuilt an engine this big before, only dirt bikes and small engines but I'm ready to give it a shot. I have the service manual, follow directions really good and can hold a tight tolerance. I'm pretty sure I have all the machines to support my rebuild. Bridgeport, horizontal mill, jig bore, lathe, OD-ID grinders, surface grinder and all the tooling that goes with them. I'm going to bore it, deck the block and rebuild the head myself. I won't know how bad everything is until I open it up. I'm hoping to reuse a lot of the old parts. Yesterday's tractor seems to have everything I need for parts, has anyone used them for engine parts before? I'm not afraid to spend a little extra to get better parts. If there is a better place to get them, please Let me know. I'll take lots of pictures and ask a LOT of questions as I go. I have to work all this weekend but hopefully I'll have it on an engine stand by early next week.
   / 4400 engine overhaul #2
TISCO kits are good quality and good value. YT sells some TISCO stuff and other stuff as well. Compare YT part numbers and prices to what you find in the TISCO catalog and from other sellers.
   / 4400 engine overhaul #3
Sounds like a great project. Good luck with it.
2022 ONYX RX34 FLOOR SWEEPER (A50458)
2022 ONYX RX34...
2018 CHEVROLET SILVERADO 2500HD (A53843)
2018 CHEVROLET...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
CONTACT INFO LOT NUMBER 6 (A53084)
CONTACT INFO LOT...
1999 Ford F-550 12FT. Flatbed Truck (A51692)
1999 Ford F-550...
2024 Cynergy Cargo 2 Enclosed Trailer (A53117)
2024 Cynergy Cargo...
