4400 series MMM hydraulic cylinder
   / 4400 series MMM hydraulic cylinder #1
jeremyrjensen
Mitchell, SD
4400 John Deere utility
Goodmorning,
I have been a creeper on the site for many years, searching for information when needed, and it has been a great tool and help for issues I've had in the past, as well as an outlet for information! Now, for my first post, I have a question I can't seem to find the answer too... and it seems like I had seen someone discussing this before, but can't seem to be able to find the post about it now!
What I have is a 4400 series utility tractor with a MMM I purchased that I am installing... as well as the attatching brackets and such. As I am getting this project compelete little-by-little... i have the small hydraulic cylinder that lifts the deck... it appears there are some clearance issues with a large main hydraulic line that is existing on the bottom ide of the tractor... essentailly a clearance issue with the MMM cylinder hitting this existing line on the tractor. I am sure someone has discussed this before.... would anyone have any input on this?
My other question is on the deck height adjustment knob... on the lower lift arms there is an elongated hole where the cylinder attatches to raise and lower the deck... under the elongated hole there is another single bore hole... is this where the deck height adjustment rod attatches to the lift arms?
Thanks!
   / 4400 series MMM hydraulic cylinder #2
Welcome!! Sorry, I do not know the answer, but this will bump it back to the top!!!
2019 ALLMAND MAXI-POWER 25 GENERATOR (A58214)
2019 ALLMAND...
Unused 12x20 Carport With 10' Fully Enclosed Side Walls (A55272)
Unused 12x20...
2017 WEILER P385 ASPHALT PAVER (A52709)
2017 WEILER P385...
2016 Ford F-250 Knapheide Service Truck (A56858)
2016 Ford F-250...
2239 (A58376)
2239 (A58376)
2008 FORD F-750 SUPER DUTY (A58214)
2008 FORD F-750...
