445 JohnDeere Rpm Hunting
   / 445 JohnDeere Rpm Hunting #1
Toffy
Bronze Member
I have had a rpm hunting problem on my 445 for quite some time and decided to do something about it. Complete service All filters plugs etc.Seems to be quite a bit better but only runs at a constant rpm at idle or wide open. Anyplace in the rpm range it hunts and this is driving me crazy. Any ideas would be appreciated. I also check for fuel blockage and have on occasion used an injector cleaning additive to the fuel. Engine has just over 500 hrs.
   / 445 JohnDeere Rpm Hunting #2
G'day it sounds like you have got worn govenor linkages or it may have a light spring on the govenor rod to take out any slackness it may be broken. Good luck:)
Jon
Thanks for your input Jon. Are you talking about the external linkage that runs the butterfly. Also I didn't mention before that my engine is fuel injected 22 hp Kawasaki Engine.
2021 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A54313)
2021 FREIGHTLINER...
Pair 2 - ST225/75R15 radial trailer (A53421)
Pair 2 -...
UNUSED CFG INDUSTRIAL H15R EXCAVATOR (A52706)
UNUSED CFG...
Adams 5 ton Fertilizer Buggy / Wagon (A53473)
Adams 5 ton...
2006 FORD F-250(INOPERABLE) (A53843)
2006 FORD...
2013 FREIGHTLINER BUSINESS CLASS M2 VACUUM TRUCK (A51406)
2013 FREIGHTLINER...
