445 long brake band
   / 445 long brake band #1
mark fogleman
mark fogleman from nc I am trying to replace a brake band on a 445 long I took off the wheel and took apart the hub.. that was not the right place there was just some gears inside and some oil came out and can anyone tell me if the oil that came out was gear oil or hyd. oil if its gear oil where do you ad it back ? there is a small cover under the tractor with 2 bolts in it I took off that cover you can see the brake band in there but It looks to small of and opening to put the break band through .. please help thanks
   / 445 long brake band #2
Welcome to the Forum.
If "long" means the tractor "Long", then maybe post in a forum-specific board, so you get some good hits from Long tractor owners. I saw 445 and first thought about my old JD 445.
2020 TAKEUCHI TL 12V-2 (A52472)
2020 TAKEUCHI TL...
DOOSAN G25 GENERATOR (A52472)
DOOSAN G25...
2018 Kinze 3500 Planter (A52349)
2018 Kinze 3500...
DROME EXCAVATOR SLIDE ATTEHMENT (A50322)
DROME EXCAVATOR...
2012 Trail-Eze TE801 48ft 50 Ton Slide-Axle T/A Tilt Trailer (A51691)
2012 Trail-Eze...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2018 FREIGHTLINER...
