4500 TLB Bleed
   / 4500 TLB Bleed #1
chuck172
Platinum Member
N.E, Pa.
Kioti DK40SEH, Ford 4500TLB, Ford 8n
Is there a procedure to changing a fuel filter on the 201 diesel engine without bleeding out the injectors? It's so simple on my Kioti, but the 50 year old is tough.
   / 4500 TLB Bleed #2
Have tank at least half full.
Turn valve off at tank.
Change filter and large o-rings, the larger goes in the groove in the filter head, the smaller goes in the bowl.
Open bleeder on the filter head, turn fuel on.
When bubble free fuel come out of bleeder, close it.
Using a 5/16 wrench remove the bleed screw from the injection pump body.
With shutoff cable pulled out (off) crank engine. You will get clear fuel, then air, then fuel again.
When you get a clear stream of fuel splashing on the right front tire, install the bleed screw and start the tractor.
   / 4500 TLB Bleed
thanks Rick
   / 4500 TLB Bleed
Sorry to say it didn't work. Still had to bleed the injectors.
2006 FORD F750 XL SUPER DUTY SERVICE TRUCK (A51406)
2006 FORD F750 XL...
2008 INTERNATIONAL 4300 M7 SBA 4X2 DUMP TRUCK (A51406)
2008 INTERNATIONAL...
1827 (A51248)
1827 (A51248)
2019 HINO 268 26FT BOX TRUCK (A53426)
2019 HINO 268 26FT...
2021 NEW HOLLAND TS6.130 TRACTOR (A51406)
2021 NEW HOLLAND...
