455 won't start and diesel control module (AM120740) buzzing
   / 455 won't start and diesel control module (AM120740) buzzing #1
iowa
Bronze Member
Any idea what could be causing the no-start for this diesel engine?
I tried to start the 455 after using a leaf blower to clean off the engine and it engine didn't start. Maybe I dislodged a wire??
I checked the battery and it tested at 12.5 volts.
I have noticed the following:
--the glow plug light does not come on when the key is turned to the on position. I have engaged then disengaged the mower deck blades several times to see if it way a safety shutoff that was engaged.
-- there is a buzzing sound coming from the diesel control module (part AM120740) when the key is "on."
--the battery indicator light on the 'dash' takes a few seconds to illuminate after turning the key to the on position. When it does start to illuminate it is dim and slowly brightens to full intensity. It used to start at full intensity as soon as the key is turned to the on position.
--the solenoid does not engage when the key is turned on.
Is there any troubleshooting that you would recommend or do I need to replace the diesel control module?
   / 455 won't start and diesel control module (AM120740) buzzing #2
Do you have the service tech manual for the 455?
What is the s/n ?
Have the battery connection cables ( + and - ) been removed and cleaned?
Has the battery been load tested? How old is the battery?
14' Bi-Parting Gate (A50120)
14' Bi-Parting...
2014 Dynapac CC4200 Tandem Vibratory Roller (A52748)
2014 Dynapac...
Year: 2012 Make: Honda Model: Accord Vehicle Type: Passenger Car Mileage: 91,438 Plate: Body Type... (A51694)
Year: 2012 Make...
JOHN DEERE SKID STEER 6FT BUSHHOG (A52472)
JOHN DEERE SKID...
2014 CATERPILLAR CT6605 SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
2014 INTERNATIONAL MA025 26FT NON CDL BOX TRUCK (A52576)
2014 INTERNATIONAL...
