4620 John Deere tractor has hydraulic issues
   / 4620 John Deere tractor has hydraulic issues #1
Leo Whitten
Hagerman, NM
4620 John Deere
I've been working on repairing this tractor for almost a month.
Every time I think I have it fixed, another hydraulic problem pops
up. First it was the hoses and pipes, then the control valve, now
it looks like the transmission pump needs to be replaced along
with the hydraulic pump. I know this tractor is nearly as old as I am,
but repairs are still less expensive than buying a new one. The
worst symptom is that things that require hydraulic pressure to
function don't seem to be getting enough pressure. I've already
split the tractor to rebuild/replace clutch/PTO stuff--what a project!!!
I've also rebuilt the brakes, thank goodness that works!
Can we re-split the tractor without loosing the pilot bearing in the works???
Any suggestions or information would really help, thank you!!!
   / 4620 John Deere tractor has hydraulic issues #2
Which trans does this tractor have? If tractor has a Syncro-range trans R&R of trans pump requires no splitting of tractor.Many front hyd pumps have been replaced when in reality the front hyd pumps were GOOD. Have you flow & pressure tested either pump? Have you checked/cleaned hyd oil sump screen?
Thanks for the great info! It does have the Syncro-range trans, so no splitting is the best news of all!
I did a rebuild on the front pump when we replaced the control valve, it seems functional now. I also
removed the hose from the tube coming out of the top of the trans, and started the engine, no oil
squirted out! That seems to indicate your assessment is correct, on the hyd oil sump screen. It's a
work in progress, I'll keep you posted.
   / 4620 John Deere tractor has hydraulic issues #4
Place a container under opening,remove hyd filter, crank engine over for 30 seconds and see how much oil you get. To R&R trans pump on SR trans one needs to raise rockshaft housing to access pump.
UNUSED JCT 84" HYD DOZER BLADE (A54757)
UNUSED JCT 84" HYD...
2016 JLG 6036 TELESCOPIC FORKLIFT (A52705)
2016 JLG 6036...
2004 Ranger 195 VX Comanchee Bass Boat with Trailer (A54865)
2004 Ranger 195 VX...
1979 MACK R MODEL WINCH TRUCK (A53843)
1979 MACK R MODEL...
2013 Ford F-550 Ambulance (A55788)
2013 Ford F-550...
2005 PETERBILT 379 (A53843)
2005 PETERBILT 379...
