4710 Deere with 48 Backhoe cant remove hoe
   / 4710 Deere with 48 Backhoe cant remove hoe #11
To take it off you may have to fully extend hoe with teeth down, detach the hydraulic hoses, open the hydraulic valve for the three point, Lift slightly to remove pins, raise three point till hooks clear and drive tractor away. This is how I recall it for my JD 4200 and #47 hoe.
Note: yours may be different. Talk to a JD Service Manager.
   / 4710 Deere with 48 Backhoe cant remove hoe #12
Give us a picture of how you have the hydro lines connected now. It sounds like you don't have the power beyond reconnected correctly. That should restore function to the rockshaft.
One thing...when you raise the rockshaft, it won't go very far because of the pins. All it should do is take the pressure off the pins so you can pull them.
UNUSED AGT SSPOC HYD LOG GRABBER (A52706)
UNUSED AGT SSPOC...
SAFETY BOX FOR FORKLIFT (A52708)
SAFETY BOX FOR...
1986 Betenbender 175 Ton 10 Ft Press Brake (A59213)
1986 Betenbender...
2005 Isuzu NQR 4 door box truck with folding gate (A56436)
2005 Isuzu NQR 4...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2022 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A56858)
2022 Chevrolet...
