48" or 60" Box Blade
   / 48" or 60" Box Blade #1
Fruitguy
Stafford, NY
Cub Cadet SC2400
I have a sc2400 and will be purchasing a box blade and thought I would go with a 48" to cover the wheels but some have suggested a 60". I would prefer to have the correct size even if it is smaller.
Was wondering what others are using or have used with a 4wd 24hp SCUT.
Thanks,
James
   / 48" or 60" Box Blade #2
The main thing is making sure it covers the wheel path (tracks), and the rest depends on what your going to be doing with it. I had a SCUT (13 hp) four wheel drive that I put a 5 foot boxblade behind. It worked fine for what I was doing with it, which was spreading dirt under a beach house that a hurricane had washed out the sand under. If I needed to dig dirt and rock, it would not have done nearly as well, but due to what I needed, it worked great. It really depends on your uses.
David from jax
   / 48" or 60" Box Blade #3
I have 26 hp BX2660 and run a 48". I pull a lot of rock and wouldn't want anything larger. If I were working clean gravel and dirt id go 60".
   / 48" or 60" Box Blade #4
I have used both on my BX2660 and prefer the 48" overall.
Thanks for the input. I think I am leaning towards the 48". I can always take a couple extra passes.
   / 48" or 60" Box Blade #6
I have a 32 HP JD 4x4 and I have a 5' seems to be a good fit, especially for working it hard /digging deep.
I think your wise leaning towards the 48", a box can get pretty heavy when worked hard, it would do you no good if you were just spinning your wheels.
For a rake I would go one size up at least, I have a 6' could probably go wider if just used for fine finish work.
JB
   / 48" or 60" Box Blade #7
I run a 60" behind my JD855. It works but I do run into occasions where it's too much to pull. It's all situationally dependent. Pulling gravel up the road I run with the blade full of material. I do so in 4WD. If I'm also ripping ground with the scarfers.... I will often find myself spinning my wheels.
Maybe I need a second blade?
Case 950 8 Row Air Planter (A56436)
Case 950 8 Row Air...
1996 Transbridge Detach Low Boy (A59814)
1996 Transbridge...
2013 Ditch Witch XT855 Tracked Loader (A56436)
2013 Ditch Witch...
2007 CATERPILLAR 725 OFF ROAD DUMP TRUCK (A52707)
2007 CATERPILLAR...
19008 (A56859)
19008 (A56859)
30ft Highway Trailer Co. Lowboy (A56436)
30ft Highway...
