4in1 tidbit I learned by accident...
   / 4in1 tidbit I learned by accident... #1
Redbug
Veteran Member
Columbia, SC
Kubota L3830HST
I have a 4in1 bucket and am still learning the ropes with my tractor. I use the bucket a good bit opened up wide to doze and push stuff. It's great at that. However, for smoothing roads it works best closed and by backdragging in the float position.
But here's the tidbit...You can do a fairly good job smoothing with the bucket opened up, and lowered till the scraper is just touching the ground. Then move forward, and if you need to raise or lower the the bucket/scraper portion...CURL the bucket one way or the other...instead of raising/lowering it. The curl will raise/adjust the lip slightly...and much slower and gradual than raising/lowering it the normal way. Cuts down on the uneven ridges left in the road from overcorrecting when raising/lowering the old way. You need to go slow, too.
2017 Harley-Davidson FLHTP Police Electra Glide Motorcycle (A49461)
2017...
2015 VOLVO VNL SINGLE AXLE DAY CAB (A51222)
2015 VOLVO VNL...
2012 John Deere 7230R (A51039)
2012 John Deere...
2015 Chevrolet Impala Sedan (A49461)
2015 Chevrolet...
377811 (A48836)
377811 (A48836)
2015 FONTAINE TRAILER CO. 53 STEP DECK SPREAD AXLE (A50854)
2015 FONTAINE...
