4X20 grease issue
   / 4X20 grease issue #1
Cidertom
Benton Co Oregon
JD 4520, 2305 Aktive snow-trac ST4
Greetings: I have a 4520 that according to the manual should have grease fittings on the steering cylinder. The tie rod has fittings, but the cylinder does not. I have not chipped away the paint to inspect, but I don't even see a plug to remove to install them as per the pict. Does anyone have fittings ?
   / 4X20 grease issue #2
When I took delivery of my 2006 model year 4520 in February, the service manager was giving me a tour of all the grease points. When we got to the front of the machine he was surprised to find the changes you mention on the steering cylinder.
So I'd guess this is a recent modification from JD, unless your tractor is an older one; if that's the case then I dunno! /forums/images/graemlins/grin.gif
In any case, my 4520 has the same setup as yours...
Tom.
   / 4X20 grease issue #3
My 4720 is also set up that way.
   / 4X20 grease issue #4
I have the 4520 bought in 2004 and it has the grease fitting
Mike
   / 4X20 grease issue #5
Mike
UNUSED CFG Industrial MX50R Mini Excavator (A47384)
UNUSED CFG...
UNUSED CFG Industrial XZ20R Mini Excavator (A47384)
UNUSED CFG...
UNUSED CFG Industrial QK18R Mini Excavator (A47384)
UNUSED CFG...
UNUSED CFG...
2012 Case IH Patriot 3330 Self Propelled Sprayer (A50657)
2012 Case IH...
UNUSED CFG Industrial QK16R Mini Excavator (A47384)
UNUSED CFG...
