4x20 series vs 3x20 series cab space?
   / 4x20 series vs 3x20 series cab space? #1
orlo
Platinum Member
Guildhall, VT
JD 2305/JD 4720 cab
Hey, does anyone know is the cab on the 4x20 series bigger than the cab on the 3x20 series?
(I have a 3720 and am still thinking about trading up to a 4720). I know the tractor is bigger, but is the interior cab dimensions bigger? Does any know the dimensions of the cab (interior) on the 4x20 series?
   / 4x20 series vs 3x20 series cab space? #2
I'm 99.9999% sure the cab is exactly the same on the 3x20 and 4x20....
So the answer to your question is they are absouletly the same.
   / 4x20 series vs 3x20 series cab space? #3
The cabs are identical. Had a 3720 and now 4520 with cabs. No difference in space, layout etc.
Thanks, that's good information
   / 4x20 series vs 3x20 series cab space? #5
Cab space may be same or close to the same - but understand that they are two VERY different tractors (in case you don't already know). The 4X20 series is a LOT of tractor and if you look at one next to a 3X20 and compare for yourself, you'll see what I mean. Not picking on the 3X20 series - they are nice little tractors that definitely have their niche. Just wanted to point out that they are two different animals because many don't realize the differences.
Otter:
Yes, you are correct. I have a 3720cab and a 2305 now (Had a 3320 open also).
I'm tempted to upgrade now since I can get 0% for 60 months. :) :)
On stance alone, the 4720 with R3's (what I run) is up to 20" wider than the 3720 (In my case not that wide since I've extended mine a foot (two 6" wheel extenders).
The things I'd like would be the wider stance, more lift capacity, and the auto-leveler.
I'd miss my front mount blower though but there are alternatives for that.
Having 66hp would be a big boost over 44 also. Not that I need it but it's always nice.
   / 4x20 series vs 3x20 series cab space? #7
Otter:
Yep - these are some of the reasons I went with the 4000 series. By the way - the 0% is for 36 months, not 60. Here are the current finance offers:
0.0% fixed-rate financing for 36 months
2.9% fixed-rate financing for 48 months
3.9% fixed-rate financing for 60 months
4.9% fixed-rate financing for 72 months
I went with the 0% 'cause it's free money.....
Otter:
The 0% for 60 is only at select dealers. My dealer has it until Oct 31st. I'm not sure if it'll be extended.
I can trade up my 2007 3720 Cab/300cx (Loaded, diverter valves, mid PTO, 72" Deck, 59" sb) with maybe 220hrs on it for a 4720 like equipped except for the blower and mower for around 20K (+ what I owe on the 3720, around 10K (I took 0% for 36 at that time)[Note that I got other stuff when I got the tractor also]. I'm just not sure I'm want to get into another 60 months of payments vs 9 or 10 I have left. (Payments would be much, much less btw, but longer).
I'm still in limbo. To go bigger green or not to. :)
   / 4x20 series vs 3x20 series cab space? #9
Otter:
Great deal if you can get that financing. Sounds like you've put some thought into this..... GO FOR IT MAN!:cool:
The 4X20 series tractors are truly awesome - LOVE my 4120...
   / 4x20 series vs 3x20 series cab space? #10
Indeed, the 4x20s have massive power for their size and can be used for commercial tasks that previously required larger machines. A 66hp 4720 is more powerful than many larger machines and can use heavy commercial implements that used to be off-limits to compact tractors.
The downside is cost though, 4x20's are not cheap and quite thirsty. You can get a larger tractor for less.
8 DRILL COLLAR (A50854)
8 DRILL COLLAR...
KUBOTA L2350 TRACTOR (A51243)
KUBOTA L2350...
FLARE LINE SKID (A50854)
FLARE LINE SKID...
2007 MD-8 TRIPLEX PUMP POWERED BY 1050HP MTU ENGINE (A50854)
2007 MD-8 TRIPLEX...
Tree Boom (A50322)
Tree Boom (A50322)
197359 (A50458)
197359 (A50458)
