5 amp fuel pump fuse blowing in a 790 john deere tractor
   / 5 amp fuel pump fuse blowing in a 790 john deere tractor #1
jtaylor
Fayetteville tn.
790 John Deere Tractor
I have a 2004 John Deere tractor and the 5 amp fuse blows after about 2 seconds when running.
   / 5 amp fuel pump fuse blowing in a 790 john deere tractor #2
Welcome to tbn. I own a 790. Don't know why your fuse blows. Try posting it in the John Deere owning/operating forum. You will have better luck.
I did find today that when I disconnect the connector to the solenoid the fuse does not blow. when I connect the solenoid and turn the key to the on position the 5 amp fuse blows. Do you know how to check he fuel solenoid with and ohm meter.
   / 5 amp fuel pump fuse blowing in a 790 john deere tractor #4
the solenoid is shorting out, check for a connection from solenoid to ground.
   / 5 amp fuel pump fuse blowing in a 790 john deere tractor #5
Welcome to TractorByNet!
I moved your thread to the John Deere Owning & Operating forum. :)
I was able to find that the fuel pump was bad and causing my 5 am fuel to blow. Thanks for all your help..
1995 GMC CHIPPER/BUCKET TRUCK (A52576)
1995 GMC...
2014 Jeep Compass 4x4 SUV (A51694)
2014 Jeep Compass...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
(1) HD 24ft Free Standing Corral Panel (A51573)
(1) HD 24ft Free...
