520 clutch
   / 520 clutch #1
patriot,Oh
5083e and a 520 john deere
Hi there I have a 57 520 and can not keep the clutch adjustment tight. Several different people have worked on it and I have had deere change the clutch once.Then I had to have it changed again all within 100 hours of use an none of it being hard.
   / 520 clutch #2
Can you describe the symptoms in more detail? For example do you get a firm snap when pushing the clutch over center? Does it stay engaged or ever pop back out? Has any parts been replaced? How far have you (or anyone else had it apart?
Sorry for all the questions, but the answers will help pinpoint the problem. Likely it is worn clutch dogs as these are almost always overlooked when rebuilding a poor performing clutch. Although it could be the inner clutch facing if give never had the driving disk off the crankshaft. (You'd be surprise how many young timers don't know there is a facing back there, and only replace the outer ones.)
2021 M&J PRESHRED 4000M SHREDDER (A53426)
2021 M&J PRESHRED...
Zero Turn Mower (A55853)
Zero Turn Mower...
SHELVES W/CONTENTS (A55745)
SHELVES W/CONTENTS...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2004 Caterpillar 345B Hydraulic Excavator (A53421)
2004 Caterpillar...
2010 FORD F350 SUPER DUTY SERVICE TRUCK (A56129)
2010 FORD F350...
