5203 Location of Flasher?
   / 5203 Location of Flasher? #1
tminer250
I have a two year old 5203 (great tractor) and the Flashers/Turn Signals no longer flash or signal turns.
The fuses are good. The owner's Manual does give me fuse locations but not the location of the flasher. I am assuming there is a single flasher relay that controls both the emergency flashers and turn signals.
Anyone know where the flasher may be hidden on a 5x03 tractor?
Thanks,
Tom
   / 5203 Location of Flasher? #2
I believe it is made into the switch on that series
Hmmm. Part of the Headlight/Flasher switch, or part of the Turn Signal switch?
Neither my Emergency Flashers or Turn Signals are working. I doubt I have had two switches fail at the same time.
   / 5203 Location of Flasher? #4
Hello tminer250:
I have a 5203 tractor purchased in '05 that has the same problem, both flashers and turn signals will not work. Were you able to figure out what the problem was?
Also my hour meter stop working after only 188 hours.
Also today I went to use the tractor and the 3 point hitch would not lower at all. Contacted JD dealer and they told me that the problem was a defective rock shaft control valve that's located under the seat. I only put about 30 hrs per year on the tractor and they told me to at least crank and raise and lower the hitch every couple of months to prevent the valve from locking up.
   / 5203 Location of Flasher? #5
I have a 5210 and the technical manual shows the flasher is part of the turn signal controller. I know it is not the same tractor, but they maybe the same. I do think your dealer could tell you for sure. I have included the URL to the JD parts.
John Deere - Parts Catalog
2009 Kaufman Gooseneck Trailer and 10K Hydro-Blast (A50860)
2009 Kaufman...
2017 Mitsubishi Outlander Sport SUV (A53424)
2017 Mitsubishi...
AUTO REWIND 12V HOSE REEL (A54757)
AUTO REWIND 12V...
2015 Infiniti QX60 SUV (A50324)
2015 Infiniti QX60...
Terms and Conditions (A47477)
Terms and...
