520H ignition module replacement, how hard?
   / 520H ignition module replacement, how hard? #1
monkers
I have a 520H and think the ignition module is bad after testing according to the manual. How tough is it to replace? I have a puller for the flywheel, does the flywheel shroud have to come off or will the flywheel fit through the opening? It looks close, but appears the ring gear may not fit. Any tips? Didn't want to have to take the shroud off due to all the linkage being bolted to it for the governor. Thanks,
Craig
Well, it goes back together much easier than it comes apart. LOTS of crud behind the shrouds, even though I blow it off after each use. Put in the module and trigger, she runs again........
   / 520H ignition module replacement, how hard? #3
Good job! I'm kind of an Onan nut myself and the first one is a learning experience. I hope that was a new one you put in? I have tried used ones before and within a few months I was doing it again. The extra money for a new one is worth every penny.
2019 KUBOTA SVL65-2 SKID STEER (A51242)
2019 KUBOTA...
2015 CATERPILLAR AP1055F ASPHALT PAVER (A51242)
2015 CATERPILLAR...
UNUSED FUTURE MINI SKID STEER HYD 4IN1 BUCKET (A51244)
UNUSED FUTURE MINI...
4 Drink Hog Waterer (A50515)
4 Drink Hog...
Land Honor 3 pt Disk (A50514)
Land Honor 3 pt...
2015 JEEP PATRIOT (A51406)
2015 JEEP PATRIOT...
