540 or 1000 RPM PTO
   / 540 or 1000 RPM PTO #1
DieselD
Bronze Member
New York
Kioti LB1914home use. JD 310SG Pilot controls, Cat 325BL long stick, Sterling Actera
Just wondering if anyone, ever runs there BH at 1000 rather than the 540 speed. I tried it today and it work twice as fast (great). just hope its not hurting the pump, heat was a little more.
Danny
   / 540 or 1000 RPM PTO #2
I'd say be real careful about that. If it's designed to run off a 540 rpm PTO and you run it at 1000 rpm you'll likely harm the pump. Also, you should be careful that you're not overpressuring the system, the relief valve should take care of that but remember that it was sized for a certain flow and you are exceeding that by running the pump faster. You should look at the specs for the system to make sure all the parts will stand running at that speed/flow/pressure.
   / 540 or 1000 RPM PTO #3
Running that thing at 1000 rpm is the same thing as using niterous on an automobile.You'll get a lot more power and a lot less life.Use that new found muscle sparingly.
   / 540 or 1000 RPM PTO #4
I have used it at 1000 but turn the engine RPM's down to about 1700.
Eugene
   / 540 or 1000 RPM PTO #5
I thought PTO speed was in relation to engine RPM.My DK40 PTO runs at 540 RPM with the engine going at approx 2400 RPM or did I read that great Kioti manual wrong.I didn't know there was a choice of 540 or 1000 RPM>
Mike
   / 540 or 1000 RPM PTO #6
Some tractors have 2 speed PTO's. They have a selector lever to choose which you want and they are usually rated at the same engine rpm.
   / 540 or 1000 RPM PTO #7
Yeah it works twice as fast and will break down at least twice as often, if not very soon. Run all attachments at their rated PTO speed ONLY. Doing otherwise can be damaging to the machinery and dangerous.
Have fun safetly.
   / 540 or 1000 RPM PTO #8
I thought the rear pto was 540 in first and the front was rated at engine speed. Did I read it right?
Nelson
   / 540 or 1000 RPM PTO #9
To clarify my post; I have run it in the 1000 position with engine RPM down thus making PTO speed approximately 540 RPM. PTO speed is in direct proportion to engine speed. My first PTO speed is 565RPM at 2540 RPM engine speed.
Eugene
2000 POLARIS MAGNUM 325 ATV (A51406)
2000 POLARIS...
201907 (A54756)
201907 (A54756)
JOHN DEERE XUV835M LOT NUMBER 26 (A53084)
JOHN DEERE XUV835M...
LATE MODEL JOHN DEERE EQUIPMENT AUCTION (A53084)
LATE MODEL JOHN...
2010 FREIGHTLINER CASCADIA TANDEM AXLE MID ROOF SLEEPER (A54313)
2010 FREIGHTLINER...
