5435 MF - do you need to recharge the accunulator...
   / 5435 MF - do you need to recharge the accunulator... #1
chade1968
5435 Massey Fergeson
after you change the transmission filters? The speedshift is not working after they where changed and I am trying to figure out why?
   / 5435 MF - do you need to recharge the accunulator... #2
Never charged the accumulator in mine. Done 3 or 4 filter & fluid changes.
Did you change the valve & it's still not working? Right filters were used? Did it happen right after the service? Did a wire get knocked off somewhere?
   / 5435 MF - do you need to recharge the accunulator... #3
Accumulator is there to reduce flow surges or dips. It should not cause a complete failure of the shift. I would do what MFRED suggested and start looking for loose connections.
Yea I changed the valve but it didn't change anything... There is power to the solenoid and I can hear the solenoid switch but it does not change the gear.
   / 5435 MF - do you need to recharge the accunulator... #5
It doesn't change real quick & change back does it? Mine will do that if the C/D switch gets water in it. There's a new switch with a rubber cover to fix. Mine's sitting on the toolbox somewhere for the next time.
I really think it's something simple if it was working before the service & not now. You did use the correct filters & fluids, right?
2009 Ford F-150 Ext. Cab Pickup Truck (A55973)
2009 Ford F-150...
2019 ALLMAND BROS, INC. ALLMAND BROS, INC. (A55745)
2019 ALLMAND BROS...
(INOP) 2019 KUBOTA SVL 95-2S SKID STEER (A52709)
(INOP) 2019 KUBOTA...
Brent 420 Grain Cart (A56435)
Brent 420 Grain...
Greenworks 2700psi Portable Pressure Washer (A56857)
Greenworks 2700psi...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
