55 Gallon Fuel Drum Residue Question
   / 55 Gallon Fuel Drum Residue Question #1
NHmitch
Platinum Member
SW New Hampshire
Bolens G154/IsekiTX1300F
Hi,
Just a quick general question. I just bought a 55 Gallon drum that is basically brand new, but it once contained John Deere HyGuard hydraulic oil. I have drained the last bit out, but there is still a light coating on the walls of the drum. Possibly less than 5 ounces. I was wondering if anyone knows if this will be an issue if I mix this with 55 gallons of gasoline. I need to store the fuel to use at our farm, and it will be used over the summer with a vent in the drum. I can was the drum out with my pressure washer, but then I will need it to completely dry, and I would just assume fill the barrel now, then have to wait a week. Any thoughts on if this very small amount of hydraulic fuel will effect the fuel, or the engines I will be putting it in? Thanks for the help!
   / 55 Gallon Fuel Drum Residue Question #2
I wouldn't worry one bit about the oil residue.
If there is 5oz left over you are talking about a ratio of 1,408:1
   / 55 Gallon Fuel Drum Residue Question #3
Well everyone has an opinion, but in my opinion, no, not a problem at all. But if you are worried about it, why not take a quart of gas or better yet diesel and put it in and agitate the drum and pour it out, Then you would have such a small amount of the hy-guard left that there is no way it could hurt anything. Be careful though as you will be making a lot of fumes inside the drum. No sparks please! This is why the diesel would be better. but if it was me.. just use it.
James K0UA
   / 55 Gallon Fuel Drum Residue Question #4
I've dumped old 2 stroke fuel into all sorts of 4 stroke engines to burn it up. The amount of oil you're talking about wouldn't even come close to that.
Great, thanks for all the advice! I always worry about damaging my engines, and that makes me feel much better about using the drum!
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A53472)
UNVERFERTH 330 -...
2003 FREIGHTLINER FL80 DUMP TRUCK (A51406)
2003 FREIGHTLINER...
2020 HYUNDAI TRANSLEAD 53X102 REEFER TRAILER (A52576)
2020 HYUNDAI...
2016 Land Rover Range Rover Sport AWD SUV (A51694)
2016 Land Rover...
New Long Forks (A53002)
New Long Forks...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
