5610 Injection Pump Timing
   / 5610 Injection Pump Timing #1
derekuk101
Bronze Member
KY
M5-111, M8540, M4900, Ford 3600
Can anyone tell me how to set the timing on a 5610 injection pump?
   / 5610 Injection Pump Timing #2
what pump does it have if it is a cav which it should be. it should have a key way cut into the drive gear and on the pump shaft and u fine tune it with the three bolts where u bolt the pump to the timing cover. if it is a sims u have to set the pump flywheel on 18 degrees and line the to marks up on the front of the pump shaft and then bolt in it will either be in time or 180 degrees out and u fine tune the timing by the three bolts on front of the pump.
2025 20ft. G70 Cargo Transport Chain (A51692)
2025 20ft. G70...
2020 Chevrolet Silverado 3500 HD 4x4 Service Truck (A52377)
2020 Chevrolet...
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
2019 FREIGHTLINER 108SD DUMP TRUCK (A51406)
2019 FREIGHTLINER...
2018 Ford Explorer AWD SUV (A51694)
2018 Ford Explorer...
