5640-SL Ford Leaking Hydraulic Clutch
   / 5640-SL Ford Leaking Hydraulic Clutch #1
Sam4
Benton, Louisiana
Ford 5640-SL
I have a 93 model Ford 5640-sl with cab, the Hydraulic Clutch keeps loosing Fluid, and is dripping from under the tractor, how can I access the hydraulic lines, and or clutch actuator? Are the hydraulic lines Metal All the way to the actuator ? does the case have to be broken apart to check this?
   / 5640-SL Ford Leaking Hydraulic Clutch #3
There is a part rubber line on the outside of the housing from the clutch master cyl. to the line that goes into the housing. From there it is metal. The slave cyl. is leaking and the tractor will have to be split between the trans. and the eng.. Replace the unit, and it's probably best to replace the clutch disc also. I just replaced the rubber line on a 6640 last week. Sure was glad I didn't have to split the tractor to get to the slave cylinder.
Gary
I will have to do more investigating, Hope I don't have to split the case.
Thanks for the help!!
2020 Ford F-250 Pickup Truck (A51692)
2020 Ford F-250...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A52577)
2017 FREIGHTLINER...
NEW Woods Reverse Rotation 5ft Tiller (A53472)
NEW Woods Reverse...
2015 INTERNATIONAL 4300 26FT BOX TRUCK (A52576)
2015 INTERNATIONAL...
RoGator RG1100C (A53472)
RoGator RG1100C...
