60" BB with 20HP CUT ?
   / 60" BB with 20HP CUT ? #1
smokedtires
Bronze Member
Lysander NY
60\" BB with 20HP CUT ?
Hi all, I ordered a 48" King Kutter CAT1 BB from TSC about a month ago and they still don't have any details of when it'll be in. I'm wondering if I could just buy the 60" they have there or if it'll be too much for my tractor? Has anyone tried a 60" with a 20HP diesel CUT?
I would be willing to buy from someone else locally if I had an idea how to locate a box blade dealer.
TIA
   / 60" BB with 20HP CUT ? #2
Re: 60\" BB with 20HP CUT ?
Don't even think about it, that 20hp tractor won't pull a 60" BB. You will be greatly dissapointed.
It will have a hard time pulling a 48" in heavy clay if you don't fill the rear tires.
   / 60" BB with 20HP CUT ? #3
It's not about HP, it's about traction force. You should be able to find the rateing for your's somewhere, but I would be surprised if it was more than 1000 pounds. There are of course a lot of variables that effect that number such as tractor weight, tire presure, tread condition, surface that wheel traction is being applied to weight distribution, ect so you may not even be getting that much force in some conditions.
Soil is going to weigh around 80-100 pounds per cubic foot(again lots of variables with moisture and composition). A 60" box scraper with I am guessing about 3' sidewalls 12+ inches high will hold around 15 cubic feet or 1200 pounds of soil/rock when full. Add the impliment weight and the drag involved when you try to move it across the ground and you are talking some serious force required.
A full 48" X 24" X 12+" box will probably hold around 700-800 lbs of material when full.
   / 60" BB with 20HP CUT ? #4
I would ask them if they could get it from another store. If the store is not meeting your needs, go to the website and send an e-mail to corporate. I had to do that over customer service on a $30 item and the regional rep. contacted me and took care of the problem. The store manager dropped off a gift certificate at my house.
I'm not one who constantly complains, but can't stand poor service. In the same token, when I get good service I also send an e-mail and let them know.
   / 60" BB with 20HP CUT ? #5
I have the 4' KK Box Scraper. I can't pull it when it fills up. Actually, I've never had it full because my tires spin before that happens. My soil is very rocky and very hard. I only have a 23hp diesel sub-cut with ag tires.
You might want to look at the Woods GBC48 Estate Series Box Scraper (holds 9 cu. ft.) or the King Kutter 4' XB Series (sold at TSC). The walls are not as high and it's not as heavy as a standard size 4' BB. I'm going to get one of those.
It looks like the consensus is that I should stick to a 48". the thing with the XB series, is that it may have smaller pins than the CAT1, but I'm not 100% positive on that, probably not a big deal since I'm sure I can change them out.
Now to go and bug them at TSC or start looking around for a Woods!
   / 60" BB with 20HP CUT ? #7
I have a 60" with a 22HP Bota. It's too much BB.
But I have it and don't have a 48", so I use it. If I were buying one, I'd get 48".
Our heavy clay soil can't fill the BB at all, but for smoothing, it works ok. And I mainly use it for rear ballast for FEL work. It does great at that!
Ron
   / 60" BB with 20HP CUT ? #8
</font><font color="blue" class="small">( It looks like the consensus is that I should stick to a 48". the thing with the XB series, is that it may have smaller pins than the CAT1, but I'm not 100% positive on that, probably not a big deal since I'm sure I can change them out.
Now to go and bug them at TSC or start looking around for a Woods! )</font>
I don't know your soil or what you want to do, but if you can find an off size like 52", I think you'd be happy with it. The thing I don't enjoy about mine is that it is about the same size as the rear of the tractor, so I can't get up close to anything parallel wise.
A 52" would give ME just enough extra width to get up agaisnt a building or fence line and drag dirt. I have the 48".
I don't have any problems pulling my 48". I bought a lighter duty 15-48 Kioti box, made my Midwest a good maker. In the lightest boxes, I'm sure I could pull a 60" but I don't have clay soil, mostly heavy sandy soil. I'd love to go 60" and may in the future. My tractor is 21 gross HP.
John
   / 60" BB with 20HP CUT ? #9
Either woods or landpride does make a 54"ish BB - Or atleast it is listed on the brochure I picked up a long way back..
I was was also wondering about a 60" BB and a SCUT - I want a JD 2305 and my Dad has a 790, so I was thinking about something both could use..
good luck
Brian
   / 60" BB with 20HP CUT ? #10
I'm going to echo Wushaw... a 60" box blade is too big. I put a little over 4 hours on my 20 horse CUT this weekend using a 48" Rhino box blade, and when the blade is full that tractor is really gruntin'.
It seems ridiculous to me that TSC would make you wait over a month to get your box blade. I'd lean on them a little, tell them you're done with waiting and that they should get you one from another store or something. If you don't get any satisfaction, go buy one somewhere else. There's got to be a vendor who advertises here on TBN who would ship you one at a competitive price, and you'd probably end up with a higher quality BB.
2016 Ford Explorer AWD SUV (A53424)
2016 Ford Explorer...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A53473)
2019 Krause...
2009 Volkswagen Jetta Sedan (A51694)
2009 Volkswagen...
2014 CAT  299D TRACKED SKID STEER (A53843)
2014 CAT 299D...
2011 MACK CHU (PINNACLE) (A53843)
2011 MACK CHU...
