60 inch heavy duty tiller
   / 60 inch heavy duty tiller #1
David USMC
Bronze Member
Mt Pilot North Carolina
Jd 345
My dealer stated that a 60 inch heavy duty tiller may be a bit much for a B series....better for the L series. Property constraints dont allow the bigger tractor...does anyone agree with the dealer.
   / 60 inch heavy duty tiller #2
A couple of thoughts...
How much does it weigh? What are you going to be doing with it? How about a model number and manufacturer as my take on HD may be different than yours. I have not seen a HD tiller with a chain drive -- they all go back to gear drive for the HD versions. They are kinda expensive for the HD models unless you are going to till several acres. The main parameter for most people is to be able to till out all traces of the tractor tires either by being wide enough or being offset to one side.
In my rocky soil a 5 ft HD tiller would probably be pretty hard on your tractor with 1000# bouncing up, down, and sideways.
   / 60 inch heavy duty tiller #3
David, I agree with Wen. You'd have to say what you're called "heavy duty" and what it weighs. Like Wen said you would prefer one wide enough to cover your rear tracks and any B series will handle one that wide, but maybe it wouldn't be what someone calls "heavy duty."
Bird
2015 JOHN DEERE 624K WHEEL LOADER (A51406)
2015 JOHN DEERE...
2005 FORD F-650 (A52472)
2005 FORD F-650...
RHINO / ATHENS  18FT DISC (A52472)
RHINO / ATHENS...
2012 Altec WC126A Chipper S/A Trailer (A51691)
2012 Altec WC126A...
2013 PETERBILT 365 T/A DUMP TRUCK (A51406)
2013 PETERBILT 365...
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
