613 mower
   / 613 mower #1
Arsavoie
Case xj70
Are the bolts that hold the blades are they metric or sae. Cause I need to remove them to resharpen them
   / 613 mower #2
:welcome:
I'm sure metric, but recall using an sae socket on them.
Measure across the nut but seems if my short memory is even close, it was 1 1/2 socket in a 3/4 set using the long extension and breaker with a pipe for some extra leverage.
What I do is sharpen them in place with an angle grinder. Just pick up my 513 with the FEL and stand it on its edge. Work standing up. Might get some oil from the gearbox vent but put down a rag if concerned.
edit: socket size, as the manual says 1 1/2 " and tighten to 433 lb-ft torque
2008 Chevrolet Suburban SUV (A51694)
2008 Chevrolet...
Garbage Truck (A51692)
2018 FORD F-450 XL FLATBED TRUCK (A51406)
2018 FORD F-450 XL...
INGERSOLL RAND G80 GENERATOR (A52472)
INGERSOLL RAND G80...
5ft Rotary Tiller (A51573)
5ft Rotary Tiller...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
