6300 - Air Conditioner Fan In Cab Not Working
   / 6300 - Air Conditioner Fan In Cab Not Working #1
JD5210
Veteran Member
Virginia
5210 MFWD
My neighbors dad has a 1993 cab 6300. In talking with his dad, he said the fan in the cab for the air conditioner was not working. He said if he jumps the relay (I do not know which one) it works. He said he has replaced the relay and it still does not work.
Not much to go on, but thought I would see, if anyone had any ideas.
Does anyone have a wiring diagram for a cab 6300?
   / 6300 - Air Conditioner Fan In Cab Not Working #2
Power or ground side switches, are used to turn relay on and off. Check all fuses and ground connections, or may have a blower resistor that went bad. Most relays will have a wire diagram on them.
Thanks, I will share you response with my neighbors dad.
   / 6300 - Air Conditioner Fan In Cab Not Working #4
My A/C went out on my Massey Ferguson cab last year with the exact sounding problem. I also jumped the relay and it worked. Replaced the relay and it worked for a week then blow again. Called and talked with a good mechanic friend who referred me to a guy that works with auto A/Cs who had the same responds as my friend. After describing my problem they both said it was the blower motor. I replaced it ($230) and have been cool since. For what it's worth...
2019 Allmand Night-Lite V-Series S/A Towable Light Tower (A52377)
2019 Allmand...
2000 Kenworth W900 - 3406E CAT Engine - 78,980 Miles (A55301)
2000 Kenworth W900...
Neckover GL24-2-7K Gooseneck Trailer  24ft Deck, Dual 7K Axles, 14K GVWR (A55218)
Neckover GL24-2-7K...
2022 BOBCAT T770 SKID STEER (A52705)
2022 BOBCAT T770...
2018 FORREST RIVER CRUISE LITE CAMPER (A52472)
2018 FORREST RIVER...
2007 INTERNATIONAL MA025 (INOPERABLE) (A52472)
2007 INTERNATIONAL...
