6640 PTO
   / 6640 PTO #1
jimg
Veteran Member
From the NH parts diagram I see there are 3 PTO setups....fixed speed, manually selectable and shiftable. Has anyone converted from one type to the other or perhaps know whats necessary to do so? Its not clear from the parts diagram whether the conversion can be done by going in from the back or the tractor has to been split.
   / 6640 PTO
Got an answer from my dealer...the PTO isnt convertible from one to the other b/c the housing is diff....at factory only option. Just in case anyone is interested to do this. I was looking at a tractor w/ a 540 PTO but the tach also has a 1000 rpm mark too.
   / 6640 PTO #3
Some units are capable of swapping the pto stub in the rear, and thus change between 540 and 1000 rpm . My 7610s is like this.
soundguy
   / 6640 PTO
Right...it seems this tractor was built in one of 3 ways: unchangeable (PTO speed is fixed at a single speed), manually changeable (like yours...pop out a snap ring and flip the PTO stub changes PTO speed)) and shiftable (where the speed change is done via a shift lever from the seat). In the shiftable version its not clear if there are 2 PTO shafts on the rear end or the stub has to also be changed out. The one Im looking at is the fixed speed type and I wondered how difficult it would be to change to the second type. It seems the answer is 'it cant'.
   / 6640 PTO #5
I'm surprised they made so many options.. seems the 'swap' option would have been a good base design that would work for either.
soundguy
   / 6640 PTO
Ya I know. Dont know how the variations fit into the S, SL and SLE scheme but I suppose theres some relationship. Also odd about diff housings depending on configuration. Guess at that time it was cost effective.
1 pallet of Truck equipment (A53117)
1 pallet of Truck...
2009 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2009 DRAGON...
LOT LOCATIONS (A54313)
2018 FREIGHTLINER BUCKET TRUCK (A51406)
2018 FREIGHTLINER...
Toro Z Master 2000 Zero Turn Mower (A50324)
Toro Z Master 2000...
