Rotary Cutter 7' or 8'
   / 7' or 8' #1
orangeboy
Pickens SC
Kubota M6040
Greetings,
This is my first post. I'm considering a Kubota M-6040 cab tractor to cut 40 acres of pastures. I'd like to keep the rotary cutter under $5k and was wondering if anyone had insight as to whether an 84" single blade is better than a 96" four blade? My wife will be mowing the marjority of time, so ease of use is important. Any comments on the tractor selection would also be welcome. I've been quoted 31,500 for a 2 WD cab & air with a few options. My land is fairly flat and I don't believe I need to spend the extra 4k for 4WD. Many thanks, Orangeboy:)
   / 7' or 8' #2
is the 96 incher a finish mower?
   / 7' or 8' #3
My preference with that much acreage would be our Woods DS1260, but given your budget, I would go with the twin spindle 8' as it won't stick out so far in the back, something like the Land Pride RCR2596. Other manufacturers make similar models.
I use the Land Pride RCR2672 on my L5740 that I use for small fields, road ditches and trimming, but for that much acreage, at least for me, the wider the better.
   / 7' or 8' #4
You have pleanty of power for the 8' mower, and I agree....with that much acreage the better.
And a as tripleR mentioned, the 8' twin isnt nearly as long, so it is a little more maneuverable. It is only about 4' long. (think 2 4' cutters side x side) vs the 7' mower being all of 7' long.
2004 MACK GRANITE CV713 DUMP TRUCK (A51406)
2004 MACK GRANITE...
2019 CATERPILLAR 299D2 SKID STEER (A51242)
2019 CATERPILLAR...
Case Ih 2388 Combine (A50514)
Case Ih 2388...
Wooden Dump Barge Wagon (A50515)
Wooden Dump Barge...
2013 TRAVIS BODY & TRAILER, INC. ALUMINUM BELLY DUMP (A50854)
2013 TRAVIS BODY &...
2018 INTERNATIONAL 4300 26FT BOX TRUCK (A51219)
2018 INTERNATIONAL...
