Fighting glow plug issues again. About 40 degrees this morning. 12 volts is only supplied to the plug for less than one second and the light goes out and the voltage stops. I want to check the water temp sensor and it appears there are two in the thermostat housing. One is probably for the temp gauge, one is for the glow plug module.
The one on the left (to the rear of the engine) reads 0.000 ohms and the one on the right (front of engine) reads about 1450 ohms.
I guess I could run it, and unplug them one at a time and see when the gauge on the dash goes to cold?
I'm assuming the one on the left is probably the glow plug sensor since the gauge appears to be working?
If anyone knows what the glow plug water temp sensor should ohm out to, I'd appreciate knowing that also.
Thanks. -Dave
Thanks. -Dave
