737 ZTrack Kawasaki 23HP
   / 737 ZTrack Kawasaki 23HP #1
gregggg
maumee oh
Blew the engine (FH680D-AS04) and Deere wants $3000 for the engine alone with no install. Seems as if Deere has this engine on a restricted list which you can't find it other than through your Deere dealer. I found a similar engine (FH680D-S08) which appears to be the same only doesn't have the shaft and pulley coming out the flywheel side oif the engine. This engine is around $1,800. Wondering if I can purchase it and bolt my shaft / pulley on it and be okay? The pully is used to drive the belt for the hydraulics on each wheel. Thoughts / Comments? Thanks,
   / 737 ZTrack Kawasaki 23HP #2
I have the same problem described above. I have a John Deere 737 with a Kawasaki FH680D Engine that is blown. Has anyone replaced the engine with a new Kawasaki FH680D-S08 or FH680D-S01 engine? If so, can you tell me exactly what modifications you had to make?
FIRESTONE 9.5L-15 4 RIB TIRES (NEW CONDITION) (A55301)
FIRESTONE 9.5L-15...
2018 FREIGHTLINER BOOM TRUCK (A51406)
2018 FREIGHTLINER...
2016 Chevrolet Traverse LS SUV (A53117)
2016 Chevrolet...
1988 Kenworth W900B Dump Truck with 3406B CAT (A55218)
1988 Kenworth...
2024 BCL Fabrication Landscape Dump Trailer - Heavy-Duty Utility Trailer for Mulch Debris Hauling (A55218)
2024 BCL...
2020 HINO 268 26FT NON CDL BOX TRUCK (A54313)
2020 HINO 268 26FT...
