753 Bobcat Skid loader bucket wont lift or tilt SOME TIMES!!!
   / 753 Bobcat Skid loader bucket wont lift or tilt SOME TIMES!!! #1
joemac4905
Athol Idaho
753 Bobcat
Some times , not all the times my bucket on my 753 Bobcat won't lift or tilt. It has foot controls for this action. The lever , forward and backward operates ok. Any help or info. will be appreatiated.
Thanks Joemac.
   / 753 Bobcat Skid loader bucket wont lift or tilt SOME TIMES!!! #2
If you install a gage in the hyd circuit for the lift and tilt, you will see when you have pressure and use it to trouble shoot and monitor the hyd system.
You could also make a gage test like these and plug into which ever circuit you want to monitor and trouble shoot.
Whenever you operate a hyd valve, you should see any pressure developed, and if no pressure, the spool is not working, or the pump is not pumping, or you have a severe leak.
Anyway, just lifting the bucket will only show about 500 psi, and when raising a fully loaded bucket, it might show upwards of 3000 psi.
If you put a QD half in the drive circuit, and plug the gage in, you can get an idea of the power of your drive system.
Will try and let you know. Thank you
Joe
   / 753 Bobcat Skid loader bucket wont lift or tilt SOME TIMES!!! #4
As I remember there is a safety interupt for the loader on the bobcats. Usually activated by the safety bar being plled down. That switch could be going, dirty, or damaged also.
2016 Ford F-550 Palfinger PSC3216 4,000LB 2 Ton Crane Service Truck (A51692)
2016 Ford F-550...
UNUSED WOLVERINE PT-16-01C 3P QUICK ATTACH (A54757)
UNUSED WOLVERINE...
UNUSED WOLVERINE LHR-51-23W 1R RIPPER (A54757)
UNUSED WOLVERINE...
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2006 John Deere HPX Gator 4x4 Utility Cart (A53421)
2006 John Deere...
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A55301)
NEW HOLLAND 706 30...
