755 johndeere wont run
   / 755 johndeere wont run #1
avdks
Campo Calif
755 johndeere
i have a 755 jd diesel rebuilt engine rebuilder ran engine on stand dropewd it in tractor hooked up fuel supply bleed fuel system had previously replaced injectors and glow plugsbut will not run any ideas?
   / 755 johndeere wont run #2
try a new fuel (usually rolling hulks have sat for years) the fuel is worthless after just 2 years. It usually turns smelly and will not ignite.
   / 755 johndeere wont run #3
Don't know what a "rolling hulk" is,
but avdks :welcome: to TBN
I would have a one-on-one talk with the engine rebuilder to go over in detail what may be your trouble.
Otherwise, will need some more detail from you about what is happening and what has been tried.
   / 755 johndeere wont run #4
Who put the engine in the tractor? you? Once the fuel was disconnected at the 1st run, transported & hooked up again, the air needs to be bled out AGAIN.. or it will never start..
Does it have ant "safety" features on the machine? They are disconnected or powered up on a dyno run.. {inoperative}
BUT once back in the machine, they are hooked back up.. neutral safety switch maybe??
I'm leaning towards AIR in the system.. especially if it ran before install..
   / 755 johndeere wont run #5
I agree with the pump guy above^^^
Did you hook up the 12 volts to the injector pump fuel solenoid?
aerator (A52377)
aerator (A52377)
2017 INTERNATIONAL PROSTAR (A53843)
2017 INTERNATIONAL...
2007 Chevrolet Impala Sedan (A51694)
2007 Chevrolet...
UNUSED FUTURE XJ3T 3TON 30" HYD THUMB CLAMP (A51248)
UNUSED FUTURE XJ3T...
20 ft. Shipping Container (A53117)
20 ft. Shipping...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
