770 ignition switch wiring and Thermostart
   / 770 ignition switch wiring and Thermostart #1
yelloh564
I am trying to help a friend out with a recently purchased JD 770.. The ignition switch was replaced just before he bought it. since then he has put a new battery in it as well. It will not start after being run. Charge the battery for 3-4 hours and it starts fine. I checked the voltage at the battery with the engine running at 1500RPM and again shut down. voltage was 3 volts less with engine running. ??? found the voltage rectifier/regulator with severe burn marks on the + terminal... decided to look at the ignition switch.. The TS appears to be wired into the ignition switch improperly. Can anyone supply a wiring diagram that shows the wire colors and where they should be attached the the ignition switch?? The TS appears to be a grid?? in the intake just upstream of the intake manifold, I unplugged and the voltage at the battery went up 7 volts.. It is currently wired into the ignition side of the switch and Ts terminal..I think it is draining the battery faster than the alternator/ regulator can replenish.. Many thanks in advance. my email addy yelloh564@msn.com
   / 770 ignition switch wiring and Thermostart #2
Here you go.
This is the electric diagram for the American Yanmar YM240 (and Japan-market YM2000), from about the same time that Yanmar was building the 770 for Deere. Should be close enough to get your switch wired.
I think that Deere key fits a Yanmar, so they likely use same switch.
70pc. 12ft.x 3ft. Black Metal Roof Panels (A53424)
70pc. 12ft.x 3ft...
2011 TEM 50' FLARE STACK (A53843)
2011 TEM 50' FLARE...
2021 Dodge Durango SUV (A55758)
2021 Dodge Durango...
6-NEW ALTERNATORS (A55745)
6-NEW ALTERNATORS...
Teakwood Dining Table (A55758)
Teakwood Dining...
Cub Cadet Kohler mower 7000 series (A50324)
Cub Cadet Kohler...
