'79 ford 1700 4x4 front axle snapped
   / '79 ford 1700 4x4 front axle snapped #1
MikeLee
ford 1700
hi guys...we broke the left front axle at the hub(common problem?).found an updated axle(better,stronger,faster?)for 1200 but since money is an issue(when isnt it?)i was curious to know if anyone here knows of a replacement axle.
will have to bite the bullet pretty soon as tractor is stuck in field.hehehe....but thought id take a chance and ask around.
thanks in advance : )
mike
   / '79 ford 1700 4x4 front axle snapped #2
Will a 1200 front axle fit a 1700?
   / '79 ford 1700 4x4 front axle snapped #3
The update is the way to go as it is heavier and eliminates a problem of an under designed axle.
You could try West Kentucky Tractor Parts (270) 462-2191 for a possible dismantled unit.
   / '79 ford 1700 4x4 front axle snapped #4
Check with Rock Valley tractor parts, they have used and new parts, several new parts are manufactured just down the street, IN THE USA!!!
All there used parts are, cleaned and stored inside warehouses. If they dont have it they will tell you were to find it.
Dave
thanks guys...got tractor back to barn(need landscaper now: )...will probably end up with improved axle but ya know...as soon as i get it up and runnin,the other side with go.thats usually my luck..
thanks again for the info.
   / '79 ford 1700 4x4 front axle snapped #6
hey did you get this fixed? if so, how? is it still lasting?
thanks
hey all....
ended up gettin an axle from a 1900...also found part to fix 1700 axle and i would like to sell it...any idea what i should ask for the 1979 1700 4x4 front axle?
thanks in advance..
mike
   / '79 ford 1700 4x4 front axle snapped #8
lots!! those things are gold
   / '79 ford 1700 4x4 front axle snapped #9
OK the question was posed ..will a 1200 axle work in a 1700? The original poster said he used a 1900 axle in his 1700. I posted a new thread asking if I could use a 1500 axle (or parts) in my 1700. No replies.
CAN THE AXLES BE SWITCHED FROM ONE MODEL TO ANOTHER WITHOUT ISSUES??
I am sitting on a good deal for a parts 1500 here but dont wanna waste my money if I cant use the parts to fix my 1700 or the entire front axle. The tire size is different and the parts book has different listings for the internal gears. I dont want to tear things up worse.
   / '79 ford 1700 4x4 front axle snapped #10
Parts catalog shows the 1700 and 1900 share front axle/parts. The 1500 shares front axle/parts with the smaller 1300.
2015 Redi Haul Tilt Deck Equipment Trailer  (A52384)
2015 Redi Haul...
2013 UTILITY VS2RA 53FT REEFER TRAILER (A52141)
2013 UTILITY VS2RA...
2009 IC Corporation PB105 School Bus (A51692)
2009 IC...
2025 New/Unused Wolverine Pallet Fork Extensions (A51573)
2025 New/Unused...
2019 CATERPILLAR 289D3 SKID STEER (A51246)
2019 CATERPILLAR...
2014 MACK CHU DAY CAB (A52472)
2014 MACK CHU DAY...
