797 Z Track PTO problems wiring diagram
   / 797 Z Track PTO problems wiring diagram #1
Mantoon3
Washington Parish
John Deere
Hi all,
Was previously registered as Dusty Road but couldn't remember the password and the email I used to create the account is no longer active...
I am the "proud" owner of a John Deere 797 with 1500+ hours on it. it's on it's 3rd engine but I am sure the PTO is original. I am having a problem with the PTO engaging intermittently. I replaced the switch because a) it was cheap and b) it would sometimes turn off on its own. That did not fix the problem. I am getting 12v+ to the PTO with the switch on, whether I am in the seat or not. Is there anyway to check to see if the PTO is bad? Can I just hit it with a completed 12v circuit to test? I don't want to throw a $300 PTO at it just to see if it sticks!
Edit: after more research I'll check the air gap when I get home and post my findings
anyone have a wiring diagram???
Thanks,
Mitch
Well, I applied 12v fully charged battery to the PTO and it clicked but barely moved. The PTO it self is riveted and apparently non-adjustable. Everything else seems to be working ok so I guess I'll get a new PTO unless someone thinks I'm overlooking something.
UNUSED JCT 84" PUSH BLADE (A51248)
UNUSED JCT 84"...
2007 VOLVO VHD64 TRI AXLE DUMP TRUCK (A53426)
2007 VOLVO VHD64...
2018 Ford F-150 Ext. Cab Pickup Truck (A51692)
2018 Ford F-150...
JOHN DEERE 7210R LOT IDENTIFIER 249 (A53084)
JOHN DEERE 7210R...
2016 FORD F-150XL SINGLE CAB TRUCK (A51406)
2016 FORD F-150XL...
