7T DS - CT450, Rear Wheel Studs
   / 7T DS - CT450, Rear Wheel Studs #1
SirMaxwell
TN
Bobcat CT450 HST
Okay, so I am very confused about these bolts. They are clearly stamped "7T DS"
I need to replace a couple that disappeared.
I would like to replace them with something a little longer, so that I can also add a Nut behind the hub.
However, what are they? Closest I could come to, that seems to fit, is 5/8-18
When I try and search for them, the closest I come is some information that says they are a Japanese JIS bolt and that's it. SAE size but Japanese?
I'd hate to get a 5/8-18, thread it through my wheel hubs, only to have it strip them out.
Anyone else figure this out?
Thank you.
<<cross posted to Kioti DK50 - Mod please let me know if wrong>>
   / 7T DS - CT450, Rear Wheel Studs #2
Thinking they are probably m16-1.5 pitch
   / 7T DS - CT450, Rear Wheel Studs #3
The bolts are part #01173-51670. There an M16*P1.5 metric
lock nut M16
Okay, so I have sent an email to Bobcat requesting the information on these bolts.
1 8ea 6697609 SCREW 8
2 4ea 6696255 NUT, high nut - Use W/6696792 long stud - Was 7131115
4ea 6696792 Long Stud - Was 7131115
3 24ea 18EM1632 WASHER, HARDENED - Was 6694095
7 1ea 70131457 DISC, WHEEL
I need the bolt size/thread information. I may need longer bolts than standard so I need to know the wheel hub thread size.
I have one bolt in front of me marked with a 7T over a DS, 15.96mm Dia (measured), 30mm Thread Length (measured), 1.25 Thread Pitch (measured high pt to high pt, and using a thread gauge).
Right or wrong, that is what is left in the Tractor. Everyone I talk to, including here, says they should be 16mm x 1.5 pitch and 70mm long (maybe the 2 studs)
I am known for being OCD, but really, is it just me?
Max
2014 Kia Optima Hybrid Sedan (A50324)
2014 Kia Optima...
2015 HINO CONVENTIONAL TYPE TRUCK (A52472)
2015 HINO...
2013 INTERNATIONAL SA615 ROUSTABOUT TRUCK(INOPERABLE) (A52472)
2013 INTERNATIONAL...
1999 Toyota Tacoma Pickup Truck (A50323)
1999 Toyota Tacoma...
2023 Maxx-D TDX Tandem Dual Flatbed Tilt Trailer (A52748)
2023 Maxx-D TDX...
Bobcat 3400 4x4 Utility Cart (A51691)
Bobcat 3400 4x4...
