841 powermaster low brake pedal
   / 841 powermaster low brake pedal #1
Willy Stripit
841 powermaster
First I adjusted the brakes. The right side still low. Have old pads off. The springs were on and seemed tight. The part shaped like a T that pivots to spread the shoes is worn, the bottom edge is no longer flat. I have a feeling that is why the pedal is hanging low. The other side of the T that doesn稚 come in contact with the shoes is flat. Can I disconnect the pedal and set brake from the shaft. Then rotate the shaft to utilize the other side? Or will the new shoes lift the pedal?
   / 841 powermaster low brake pedal #2
New brake shoes may affect your brake pedal height. Install new shoes and new springs if needed, then see where the brake pedal heights are and adjust if need be. Per the owners manual for the 801 series tractor, adjust the left pedal at the clevis to get the height to match the right pedal. Screenshot_20190406-153820.jpg
90018 (A48082)
90018 (A48082)
2018 Ram ProMaster City Cargo Van (A51692)
2018 Ram ProMaster...
2013 F-550 Bucket Truck (A53473)
2013 F-550 Bucket...
2005 Chevrolet Trailblazer EXT 4X4 SUV (A51694)
2005 Chevrolet...
2019 Ford F-350 XL (A50123)
2019 Ford F-350 XL...
Hydraulic 50 mm Thumb, NEW never installed (A52384)
Hydraulic 50 mm...
