853 Bobcat, It ran fine, sat for awhile, now I have no electronics, HELP!!
   / 853 Bobcat, It ran fine, sat for awhile, now I have no electronics, HELP!! #1
DDoyle
Mt.Laurel, NJ
580 Case Extend Backhoe
This is making me nuts! After use I parked and shutdown. When I'm not using regularly I will start and let it idle for 30 min or so every 1 to 2 weeks. This last time it would not turn over so I tried jumping and got nothing. I slow charged the battery, got nothing. Changed all relays, got nothing. When the key is on I have no gauges, I also have no lights when switched on. It did start with jumping over the starter solenoid BUT I can't release any of the breaks, I still have no gauges and the lights still won't work. Any Thoughts would greatly be appreciated!
   / 853 Bobcat, It ran fine, sat for awhile, now I have no electronics, HELP!! #2
Sounds like it might be severe corrosion on one or both battery cables. Or if the ground cable is bad it wouldn't start with a jump at the battery but would from a jump to the starter itself.
No, all terminals have been cleaned and all cables are in good condition. That was the first thing I checked and did. When turning the key I can hear a click at the rear. I checked for mice and any bare or knawled wiring. Does anyone know about the solf ware block mounted behind the seat? My safety panel at lower right (sitting in seat) is not activated. It has to be something really simple that I am missing. There is no reason why something like this happens unless it's simple and my dumb *** can't see it,lol.
   / 853 Bobcat, It ran fine, sat for awhile, now I have no electronics, HELP!! #4
I do know that the BICS and BOSS systems do tend to act up when corrosion causes ground problems. Since you've had all the relays out, it could be a dirty connector anywhere between the box and the panel. You might try searching over at the skidsteer forum and see if there is a similar problem and fix.
I'm glad my old M700 doesn't have any of the whiz bang gadgetry to go wrong, it's about as basic as you can get.
Thanks Flyerdan, I love this machine but anyone who owns one knows they stuff 10lbs of $#*! in a 5lbs bag and the safety systems can make you go nuts when there is a shut down. Normally I would just someone take care of it but in todays economy that's not an option. The last time I had it put in with a Bobcat dealer/service it cost me over 2k because they could figure out the problem so they just went into the "replace this, replace that" mode and when I got it back it STILL leaked hydro and they didn't replace the exhaust manifold because " it's a real pain in the @$$ and expensive" ....yup, that's what they told me!
   / 853 Bobcat, It ran fine, sat for awhile, now I have no electronics, HELP!! #6
Have you thought of mice/rodent damage? These little critters love smalll electrical wires.
Check the ingintion switch.
1. Is there 12v at the B (battery) terminal with switch on or off?
2. Turn switch on & is there 12v at the R (run) terminal?
If answer is no to #1 or yes to both, then riase the cap and start inspecting wire harnesses. There is a plug that cab harness plugs into the engine harness.
If test are yes to #1 & no at #2 - replace the switch.
Thanks SSdoxie, I have gone over every inch checking for mice/ rodent damage. I will run the test, but I do hear a click at the rear when I turn the key. Would the ignition switch cause no gauge movement and no lights. As I said earlier that I can jump the starter solenoid over and it will run but still no gauges, lights and can't release the running and hydro brakes. I have lifted the cap and inspected, unpluged, inspected/cleaned and pluged back in. I'm just trying to do all common sense things before replacing items. As I said it was and did run fine, this is not something that happened during operation and why I'm figuring something simple....I hope,lol.
   / 853 Bobcat, It ran fine, sat for awhile, now I have no electronics, HELP!! #8
Howdy,
You simply need a new battery.
Yep, I ran into this problem too. It was simply not working even after cleaning connections, charging, jump starting etc... pulled the battery, put in the new battery, bam, everything working like it should.
Thanks Daybreak, I'll head to Tractor Supply and get one and give it a try. This battery does have some age on it and regardless if it does the trick or not that is one part I don't mind replacing.
   / 853 Bobcat, It ran fine, sat for awhile, now I have no electronics, HELP!! #10
When those batteries go, they go fast. My worked great one day, and the machine was completely dark the next. The electrolyte level should be checked at every oil change, or six months. They're like the car batteries of 20 years ago, but tucked away in an inaccessible spot (at least mine is).
Kubota BX2680 Sub-Compact Tractor  4WD, 218 Hours (A55301)
Kubota BX2680...
Honda Pioneer SXS700 4X4 Utility Cart (A53424)
Honda Pioneer...
PALLET OF MILITARY STRAPS (A54757)
PALLET OF MILITARY...
2004 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2004 DRAGON 150...
2011 Ford F-350 Knapheide Service Truck (A51692)
2011 Ford F-350...
2011 WESTERN STAR  4900 SB (A55745)
2011 WESTERN STAR...
