854 Loader problem
   / 854 Loader problem #1
nybirdman
Super Member
north of upstate ny
Kubota L4240 HSTC,L3000DT
Just had my L4240 serviced(360hrs) dealer changed filters,replaced a defective third function valve.Plowed snow for about an hour returned home to refuel,got that done.......machine at idle.......wouldn't raise or lower the loader...what the ##########,raised engine speed..same deal,moved the joy stick up and down a few times,back to normal.Couldn't have been air in system,its self bleeding plus I had used for an hour with no problems,stuck spool?Did it again 15 minutes later...parked until the next snow.
   / 854 Loader problem #2
Does/did the engine labor at all while trying to lift? 99% of the time it's a QD that's not seated all the way...Unplug all of them, wipe with a rag and then reconnect them.
KennyD
NO,engine does lug at all:used the tractor today....no problem,called the dealer that serviced it just to let them know that I had a potential problem.I am thinking know it is electrical,some thing with the joy stick.They had things apart to replace the third function valve.
   / 854 Loader problem #4
I would install a 5000 psi pressure gage at the FEL valve IN port to monitor the pressure for the system, and for trouble shooting.
2008 SATURN VUE (A50324)
2008 SATURN VUE...
3014 (A50657)
3014 (A50657)
John Deere 750 Drill (A50514)
John Deere 750...
2016 Ford Explorer...
Tires (A50322)
Tires (A50322)
2021 FORD F450 TOW TRUCK (A50505)
2021 FORD F450 TOW...
