8560 audible alarm goes off after 5 minutes.
   / 8560 audible alarm goes off after 5 minutes. #11
My 8560 has the same alarm after 5 minutes issue and I only have about 35 hours on it. I have the dealer coming out for the Throttle position sensor so I'll have him bring a scavenger pump switch as well.
   / 8560 audible alarm goes off after 5 minutes. #12
Spoke with a dealer close by. They had not heard of this problem. They called the area service rep. He told me how to check the scavenger pump switch. It was bad. Replaced it every thing is back to normal with no alarms. Thanks again for the help.
I realize this is old as the hills but thought I'd ask and maybe somene will know: How did you "check the scanvenger pump switch" other than by replacing it?
   / 8560 audible alarm goes off after 5 minutes. #13
I have a Mpower 85 same problem after 11hr. You would think Mahindra would upgrade. This has been going on for a couple of years by past threads. Not good just bought tractor last week.
   / 8560 audible alarm goes off after 5 minutes. #14
When you replace the scavenger pump switch, replace it with the switch listed for the engine oil pressure switch, as it is a better quality switch and will last longer. A Mahindra service rep told me to do this, and it hasn't been a problem since.
2007 Ford F-150 4x4 Ext. Cab Pickup Truck (A50323)
2007 Ford F-150...
2019 Bobcat S595 Skidloader (RIDE AND DRIVE) (A50774)
2019 Bobcat S595...
2014 Fiat 500L Hatchback (A50324)
2014 Fiat 500L...
2017 Mack GU713 Granite Tri-Axle Dump Truck (A50323)
2017 Mack GU713...
2012 Mack CXU613 Day Cab T/A Wet Kit Truck Tractor (A50323)
2012 Mack CXU613...
2015 Dodge Challenger Coupe (A50324)
2015 Dodge...
